I want to reset the account to use.
The window does not popup.
Help: Select Account indicates a Reset is available.
After repeated searches for this option, I can not find the button.
Please tell me button location.
thanks
hime
select account to use
Re: select account to use
Hello hime,
To answer your question, please have a look at the information provided by lakrsrool in his reply to a similar post you made back in April of this year at the link below:
viewtopic.php?p=36816#p36816
The information there should help resolve the issue you are having. Please post back and let us know if it helped, or if you are still having problems.
[EDIT/UPDATE]: Hime3's problem was resolved, per his reply at the link below:
viewtopic.php?p=37116#p37116
Thank you & best regards.
