Boundary Failure
Miki
Boundary Failure
Post by Miki »
Good morning Jeff,
I have a Boundary Failure with the string 1383:
Boundary Failure.png (10.53 KiB) Viewed 31816 times
I cannot change the translation, should be possible more space for this string?
Best regards
Miki
Re: Boundary Failure
This particular field is a little unusual because of its location and the type of window that it's in. I would highly encourage an abbreviation or synonym to try to get it to fit.
Are you working on a personal translation? POP Peeper has an Italian translator who's been doing the translation for... well, probably since the very first version that had translations (the year 2002). He uses "Dim." for that text. I can send you his v5.0 translation if you're interested. Otherwise, I hope you haven't gone to too much effort :oops:
Miki
Post by Miki »
Good morning Jeff,
I agree ... it's a particular position, but enlarge 2 letter should be better than an abbreviation (no synonym available and "Dim." is very bad)
I work on my personal translation from 2016 and I know there is an official translator, but I like more mine :wink:
And thanks, but I have just updated to v5 my translation.
Regards
Miki
