Hi again
Edwin,
Yes...I did see the search results myself using the "
V5" parameter you gave in your first post, and also using "
version 5", then "
Software version 5" as search parameters. The results for "
version 5" and "
Software version 5" are shown in the screenshots below.
(The Board rejects the
"V5" search term as being too common).
- Search using "version 5" as the search parameter
- Search using "Software version 5" as the search parameter
Please keep in mind, the Board will search
only for any topic/posts in the Forums which contain the
specific terms you provide. It returns results based
on that fact alone, and not whether the topic/post contains specific information about the upcoming PP version 5 release status.
Using the "
Advanced Search" option, you can also indicate words/terms that you do
NOT want to be shown as well. This may help narrow the results which are returned.
Hope this clarifies things a bit more.
