Typing Message Tabs Right
keiser13
Post by keiser13 »
When typing a message a new line often gets tabbed right.
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> The sentence jumps right like this. [> added to create empty space.]
Backspace/delete does not undo this and I have to copy, cut and paste to restore.
This happens mid-sentence and I have not duplicated exactly what is the cause.
Typing gibberish so I can watch the screen fails to recreate.
Any one else have this issue?
Possible new under Windows 10 as never happened under Windows 7.
Re: Typing Message Tabs Right
You're probably right-justifying the text by pressing Ctrl+R (I know I've done it myself on accident, perhaps I was trying to reply to the reply...)
If that's what it is, you can return the current line to normal by pressing Ctrl+L (Left justify).
