PpTweaker default settings ?
akm
Post by akm »
Are there default settings for V4.5.3 PpTweaker, and if so where to find (and 'reset' to default if possible, or do 'manually') ?
Thanks again for your help !
akm (PPv4.5.3,W10,FFox,Office2003,Mbam,Privatefirewall,Avast)
Re: PpTweaker default settings ?
No, I'm afraid there's not a way to reset the defaults, at least not just for PPtweaker. You could reset everything by editing the ini file (after exiting POP Peeper) and then delete everything in the [POP Peeper] section -- although, I wouldn't necessarily recommend this; there's at least one item that I can think of (the admin password) which would cause you problems if you did this.
If you have a few specific items that you're interested in, I can look up the defaults. Otherwise, you can create a new ini file (specified on the command-line) and then see what the defaults are and compare with what you have.
