Re: Gmail login error May 4th
captqbec
Post by captqbec »
hi,
Since this morning...is it only me?
POP Peeper: 4.5.3.0
Webmail: 4.5.15.0
SSL: 1.0.2.14
IMAP: 4.5.2.0
SendMail: 4.5.2.0
*******Gmail [1000: IMAP] ['imap.gmail.com' (993) SSL: 1] [Smtp: 'smtp.gmail.com' (465) SSL: 1] [consec: 1]
- Error ([AUTHENTICATIONFAILED] Invalid credentials Failure)
******** Gmail [1000: IMAP] ['imap.gmail.com' (993) SSL: 1] [Smtp: 'smtp.gmail.com' (465) SSL: 1] [consec: 1]
mdv921
Post by mdv921 »
Nope, not just you. Started for me this morning as well.
adtg
Post by adtg »
I have the same problem
jeanlecoeur
Post by jeanlecoeur »
Here the same. Since this morning all Gmail accounts failed.
Using Webmail 4.5.11.0
Can't update to 4.5.15.0 "WebMail update does not apply to existing accounts"
Just downloaded and installed WebMail plugin version 4.5.15.0. Manual. Now it works again. Don not know if this was the solution or just luck.
adtg
Post by adtg »
it works again for my gmail accounts
mdv921
Post by mdv921 »
Mine has cleared up as well.
Thanks to everyone for your respective initial and follow-up reports. Gmail was down for a period a few hours ago, but does appear to be up again.
[For captqbec ]
Thanks very much for including the error message data - it provides us with more information about a problem!
Did your Gmail accounts clear up, or are you still receiving the same error message shown in your initial post? (Or, a different error message).
[For jeanlecoeur]:
Which plugin file were you attempting to download/install when you received the error message you indicated - i.e., the EXE or ZIP version?
** Jeff and other members of The Esumsoft Team will be dropping by the Forums later to further review the issue you're reporting, and provide additional feedback.
[For Adtg]
Welcome to the Esumsoft Forums! :)
As our newest member, The Esumsoft Team requests that you please review the following Sticky topic:
Thank you and Welcome aboard!
Gmail did have an outage earlier this morning, and they continue to have higher than normal reports of problems:
https://downdetector.com/status/gmail/
According to the comments, it affected imap, pop3, and smtp
