Pop Peeper and POP Peeper Tweaker ?
sportman40
Post by sportman40 »
Pop Peeper and POP Peeper Tweaker are these two separate things ?
Re: Pop Peeper and POP Peeper Tweaker ?
The Pop Peeper application includes various settings some of which can be found on the PpTweaker Interface pages:
These PPtweaker settings are accessed from the POP Peeper main menu under "Tools" > "PPtweaker...".
sportman40
lakrsool thanks
Was their ever pop peeper and another separate app went with it ?
I am not aware of any other than specific optional POP Peeper plugins as well as the optional "POP Peeper Plus Pack" that consists of a specific collection of plugins and utilities. Beyond this -- I'm not aware of the entire history of POP Peeper -- Jeff would be the one that would know more about this.
sportman40
lakrsool thanks I will direct the question to Jeff
sportman40
Was their ever pop peeper and a pop peeper Tweaker separate things ?
Well, there was a time when PPtweaker was an executable instead of a plugin, but it still behaved much the same way, as I recall (I think this change was made at v3.0).
OH, I had forgotten about this -- PPtweaker used to only be available as a separate download (pre-v4.0); so maybe that's what you're thinking of.
sportman40
Jeff yes PPtweaker used to only be available as a separate download (pre-v4.0 where do I download it ?
You don't. It's included with the POP Peeper installation. If you need to re-install PPtweaker, then you can re-install POP Peeper and make sure that PPtweaker is included on the components page.
sportman40
Jeff thanks
