Can Accounts List be Re-ordered?
Just wondered... Re V4.5.3, in the list of accounts on the left side of the main UI, is it possible to selectively re-order them up or down for a custom view?
Re: Can Accounts List be Re-ordered?
Hi mistertee2,
You can re-order the list by dragging-and-dropping an account name anywhere in the list you want it to appear. Another option is to edit the account name, since accounts are normally shown in alphabetical order (or, ASCII order as Jeff refers to it).
Information about the Account List is also available in the POP Peeper Help Files:
From the main UI, click [HELP] > [CONTENTS] > Accounts List, & click the [DISPLAY] button. You will see two selections; Click on "POP Peeper", then click the [DISPLAY] button at the bottom to show the information on the right side of the window.
Also, please review the information, (and additional topic link), provided in the following discussion from 2017 which addresses Account List re-ordering:
viewtopic.php?p=35452#p35452
If you have additional questions, do let us know. Other members of The Esumsoft Team may further review your inquiry and provide additional feedback.
Cheers!
Cheers!
Thanks! I wasn't able to drag and drop the account names within the UI for some reason. But adding a numerical prefix to each account, (ie; 1), 2), 3), etc) did the trick.
The "Drag & Drop" feature to re-order accounts in the accounts pane is a new function included in POP Peeper version 5.
In case you're interested, here is a link to; What's NEW in POP Peeper v5.
Also, here is a forum link to additional POP Peeper v5 Beta Information that may be of interest to you as well.
Addendum:
FYI - mistertee2 - Note: to your specific question regarding the ordering of accounts; it appears, as of this time, that this feature your asking about will not require the PRO version.
Addendum:
Reason: Edited to add Addendum comments
