Pop Peeper Exit problem
majekho
Post by majekho »
I click the pop peeper exit. I open it again. All email accounts disappeared. Please help.
System : window 10 pro 64bit
Browser : Chrome
Re: Pop Peeper Exit problem
Your ini file is probably in a write-protected folder. To check this, go to:
main menu: Tools / Options / Storage
Let us know the values for:
- Ini Location
- Data path
majekho
Post by majekho »
Ini location C:\Users\bonny\AppData\Roaming\POP Peeper\poppeeper.ini
Data path C:\Users\bonny\AppData\Roaming\POP Peeper
Ok, that shouldn't be a problem, though you may want to check if the ini file is set to read-only:
1) Use File Explorer and open:
2) Click on and then right-click the 'poppeeper.ini' file and select Properties
3) At the bottom, make sure that "read-only" is not enabled
-> if it is enabled, then uncheck it and you should be good -- try testing it
If that doesn't work:
- Is it just your accounts that are affected or are other settings affected? For example, if you move/resize the main window and then exit and restart POP Peeper, is the window where you left it or did it revert back to the original size/location?
- What about the address book? If you add a new contact (it can just be temporary), is it still there after you exit/restart?
- Do you know of anything that may have led up to this occurring?
- What version of POP Peeper are you using (main menu: Help / About)?
majekho
Post by majekho »
When I turn on the laptop every time. All email accounts are disappeared and it says welcome to pop peeper! It doesn't save email account when i turn off the laptop every time.
What if you manually exit and restart POP Peeper? For testing purposes, I don't recommend adding a significant number of accounts or configuration if you're just going to lose the data, so just add a quick account (no password) to see if it stays or not.
If the accounts/settings stick on a manual exit/restart, then there's probably something removing the data; e.g. maybe a system restore gone awry or some cleaner type of app, etc.
majekho
Post by majekho »
I try it. Thanks
majekho
Post by majekho »
I tried it but so far it doesn't work.
Jeff wrote: Tue Jul 21, 2020 3:27 pm - Is it just your accounts that are affected or are other settings affected? For example, if you move/resize the main window and then exit and restart POP Peeper, is the window where you left it or did it revert back to the original size/location?
Hello majekho,
To better assist you, please provide your responses to what Jeff has previously asked in the quote above.
Thank you & best regards.
majekho wrote: Mon Oct 19, 2020 1:54 pm I tried it but so far it doesn't work.
majekho - it would be helpful if you were more forthcoming.
So is what you are saying is that after adding an account; accounts/settings are not maintained after an exit/restart of PP?
If this is the case then Jeff had posted a couple more comments:
1) Have you done a system restore recently?
2) Do you have "some cleaner type of app" installed?
Also
3) What type of security software do you have installed?
ADDENDUM: Oh and most importantly - please provide the answers to the questions that Pete (spc3rd) has posted above (that Jeff had previously asked).
(It is difficult to assist with your issue without you supplying us the information we have requested).
majekho
Post by majekho »
1. All accounts are not maintained after exit and restart of PP.
2. Computer is not installed some cleaner apps.
3. The old PP is no problem.
I see all accounts in this file,
majekho
Post by majekho »
https://imgur.com/YRWj1nc
majekho,
For future reference, whenever you want to include an image from an external website in a post here, use the icon shown in the screenshot below:
How to include an image from an external website.
Thank you and best regards. :)
Reason: Post edited to include link to external website image.
Thank you for posting what you have.
Would you please post instead the following screen-shot:
Do the same for the file just above the one you posted - pointed out in the screen-shot. (click on the image for better viewing - use the browser back-arrow to return to forum)
Also:
2) What type of security software do you have installed?
Also: Please respond to THIS post by Pete (spc3rd) as much as you can (if you are unable to, then please explain the reasons why you cannot).
Thanks again. :)
The timestamps on your data files appear to be recent. There have been cases where something (possibly Windows Restore) causes the files to be restored after a system reboot, but I would think that simply exiting and restarting POP Peeper (as opposed to restarting your computer) would preserve the previous settings.
If you mean that you had the same problem with PPv4 in July and the problem resolved itself (or you fixed it), then whatever you did back then probably needs to be done again for the current version.
majekho
Post by majekho »
Thank you very much for all.
I resolved this problem. =D>
^ Really great news and congratulations! majekho \:D/ - after spending as much time as we all have on this topic -- how about letting us in on what the problem and resolution was? Doing so could possibly help out other forum members that might have similar issues arise some time. :wink:
