Account Section - useful features missing?
Locked
YourKoolPal
Post by YourKoolPal »
In POP Peeper Pro v5.0 Beta 22 when you right click an Account, useful features are missing
Annotation POP Peeper Pro v5.0 Beta 22.png (3.77 KiB) Viewed 18164 times
Versus options available in existing POP Peeper Pro v4.5.3
Annotation POP Peeper Pro v4.5.3.png (11.13 KiB) Viewed 18164 times
In case I have to enable some settings, please let me know.
Re: Account Section - useful features missing?
From the Main PP menu - go to "Tools" > "Options..." then select the "General" options window at the top of the left pane then enable "Advanced options" by checking the box for that option over toward the top-right of the "General" options window. This should provide you with the accounts right-click context menu functions that you found missing.
YourKoolPal
Thanks! I forgot about this setting. This is such an amazing app that once you have set things, you do not need to keep tinkering.
I guess I had enabled that setting years ago and forgot about it! :D
Your very welcome and yep, totally understandable -- it's certainly easy to forget some minor setting such as this over time -- I tend to forget something like that in just a matter of weeks at best. #-o :lol:
Locked
