Is there any way to disable this notification? (see attached)
There are times I am connected to an isolated network for a time.
Basically, I disable a network adapter that has access to the internet, and enable an adapter to an isolated network for work.
I don't want to disable the checks (because I will inevitably forget to re-enable them) once I am back on the internet connection.
Is there a way I can disable the error notifications?
Thank you for your time.
Consistant error Notice
- Attachments
- Untitled.jpg (17.72 KiB) Viewed 17244 times
Re: Consistant error Notice
You can disable POP Peeper Windows Notifications by doing the following.
Under Windows Settings select the "Notifications & Actions Settings": Then scroll down to POP Peeper to disable (turn "Off") Windows Notifications for POP Peeper: POP Peeper provides all of the Alerts that I personally need without Windows 10 Notifications (So I've disabled this setting myself - along with a lot of others as well -- as you can see ).
lakrsrool's method would also disable the notifications for new email, if you're using that.
Another method that should work is:
main menu: Tools / PPtweaker
Troubleshooting page
Set "number of consecutive errors to display tray error icon" to some very high value
Lakrsrool method might be better if you don't use the "windows notification" for new email, because the tray icon will still display the error icon when appropriate (in case you want that feature under normal conditions, but presumably you'd get so used to seeing it that it would become meaningless anyway), so it's your choice.
Thank you. I have set it to 300.. we'll see how that works
