v.5 questions (read message, outbox, plugins update…)
lian
Post by lian »
Hello, I’m very happy to see an update version of Pop Peeper and like the new features (Wizard will be a great help).
But I meet some problems.
1. Autoupdate does not work. After clicking for autoupdate, there is a message telling that no update selected (see capture). I had to manually download Pop Peeper Plus Pack.
2. I’ve read there is and option to prevent messages to be marked as read but I did not found it
3. Dark theme : I tried to change fonts in message writing window (I was replying to a message). Some text went black. I choose "default font". Nothing changed.
OK: If I create a new message, everything is OK. So the problem seems to occur only when changing font.
4. Not a bug but it will be so cool if Pop Peeper had a Win 10/2020 look. I put a screenshot with Postbox to compare. No heavy lines for boxes borders, clean and modern icons.
Windows 10 64 bits
Re: v.5 questions (read message, outbox, plugins update…)
#1 - We are looking into this issue - please stand by. Glad to hear you managed to apply the update however.
#2 - Some of the settings for marking messages as read can be found from the main menu: "Tools" > "PPtweaker...", misc page. What is it that you want to do?
#3 - Are you using the "Windows Dark" theme? I don't seem to have this problem in the "Compose" window (tested replying to message using "Windows Dark" theme) -- what font are you changing to? Do you have the "View/Compose Background:" color set to "Theme Color"? -- if not what is this setting? (can be found in the Theme Viewer at the bottom). Try using "Theme Color" if you are not using this setting. You can also change the Compose Background color to your choice in this setting.
#4 - Thank you for your feedback.
I was able to reproduce the problem with the compose text switching to black after changing the font -- thanks for reporting it.
lian
Post by lian »
Thanks for your answer.
My question relative to marked read messages was relative to this:
- Don't automatically mark messages as read: messages require you to mark-read, delete, or reply so you don't forget to reply to messages
Windows 10 64 bits
