invalid license - PLUS Pack does not activate
napouser
Post by napouser »
just bought the big pack today the one with calendar and plus
poppeeper pro activates
plus pack does not
error is
error (plus pack): invalid license (#1)
Reason: Topic title edited for better attention.
rgordon
Invalid license - PLUS Pack does not activate
Post by rgordon »
I've purchased Pop Peeper plus Pro Pack but when I try to activate Pro Pack I receive error: Error (Plus Pack): Invalid License (#1) (Device: xxxxxxx)
rgordon
Re: invalid license - PLUS Pack does not activate
Post by rgordon »
Magically it just activated...????
Thanks for both reporting the issue & updating us, napouser and rgordon. Jeff and other members of The Esumsoft Team are diligently working on several issues that have been reported today.
We appreciate your patience!
Taz305
Post by Taz305 »
I am also having trouble activating Plus Pack. Will not let me remove the old license. Pop Peeper activated fine. I bought the bundle Pop Peeper and Plus Pack today.
Welcome to the Esumsoft Forums, Taz305!
Thank you for reporting the issue you are experiencing.
As mentioned in my previous post, Jeff and other members of the Esumsoft Team continue working on a number of issues that have arisen today.
In the interim, as our newest member, The Esumsoft Team requests that you please review the following Sticky topic:
Thank you and welcome aboard! :)
Sorry! If you bought the Plus Pack since yesterday there was a problem with the way that the license key was generated. The source of the problem has been fixed and anybody's license keys that were affected have also been fixed.
The license key that you were provided should now work -- please try activating again and let me know if you have any problems.
Brakstrom
Post by Brakstrom »
I have almost the same problem, plus pack is activated but getting error anyway.
Can you verify that (most) everything under Help / About is "currently" using v5.0? There are some exceptions such as SSL, Updater, and some of the unrelated plugins. But, specifically, AntiJunk and Sent Mail Viewer should be listed at 5.0.
Also, have you restarted POP Peeper?
And, under main menu: Tools / Plugins -- make sure that AntiJunk has a checkbox next to it, which indicates it's enabled.
Brakstrom
Post by Brakstrom »
Yes,
Note that the last 3 Modules in the "About" window are not listed as 5.0 (including "Sent Mail Viewer").
Have you restarted PP?
Brakstrom
Post by Brakstrom »
Restarted several times, and tried to install a couple of times, Will try a clean install and see if it works. Shouls sent viewr be 5.0? cant update because there is no update available.
Press the "Check version" button on the Help / About page -- that should kickstart things. It's still showing the data from v4.
