Jeff I am a lifetime member update Issue ?
Jeff I am a lifetime member I downloaded the update when I did it said trail version I can email my lifetime details please get back to me
Re: Jeff I am a lifetime member update Issue ?
Sorry, but Pro was never advertised with a lifetime license. If you bought the Premium Add-on Pack when it was still called that (ie. before Aug 2014), it was advertised with free lifetime updates. That's why I continue to honor that commitment, and why the Plus Pack updates are still free. Note that the guarantee does not necessarily apply if the "Plus Pack" was purchased since Aug 2014 because I didn't want different license agreements for each product, but the Plus Pack update is free for all Plus Pack licensees in v5.
So, sorry for any confusion but, yes, you do need to pay the upgrade fee for Pro v5 to use Pro v5; or you may go back to Pro v4 where your license is still valid. This and more details are available on the Upgrade page.
sportman -- never post personal information in a public forum, including email addresses and license keys.
Your Plus Pack is activated.
WebMail now requires a subscription. Most people do not need the webmail subscription, refer to the Webmail subscription page for more information.
You may have disabled the Notification skin. If you hover your mouse over the gray text it should provide more information.
Jeff I use Gmail never issues am I good to go ?
^ In regards to the "Skin notification" plugin -- As I recall sportman13 - I think you had decided to not to use this message alert (plugin) and instead decided to go with the DTA if I'm not mistaken (hence as Jeff mentioned the plugin is probably disabled).
You should be good to go.
lakrsrool how do I use the message alert (plugin) I do not want DTA disabled).?
You do not have DTA disabled if I'm not mistaken (this is what you are using) - you had decided to use the DTA and not the Notification skin (which you will probably find disabled because you decided not to use that plugin).
If you're not sure what you are using then post a screen-shot of your message alert and we will confirm for you.
Everything should be just fine for you since you have been using what you wanted - nothing has changed since you eventually decided what your preference was.
So you are good to go
-- no worries.
lakrsrool you said
If you're not sure what you are using then post a screen-shot of your message alert and we will confirm for you. here is the only thing I see
sportman13 - this is what I mean by your DTA (message alert that you use as I recall): you are all set and good to go.
If what you see when you get new messages in PP resembles this message alert popup as illustrated in the screen-shot above - then you are already using the DTA - it is not disabled -- and
lakrsrool »I do not see the Pop up in your screenshot when I get new messages in PP it dose not resembles the message alert popup as illustrated in your screen-shot -can you give me directions please
Please take a screen-shot of what you do get when you get your next new message and post it here in this topic. I will then follow up after you do this.
Addendum: btw, your message alert may resemble this (if you have your message list extended):
lakrsrool hard to give you a screenshot cause my pop peeper slide in and out from the side I always see
sportman13 - you ARE getting the alert displayed when new messages arrive - RIGHT?
If you are then you are good -- because this is what you have been using for your message alert for many months as of the time when you decided what to use back at that time (apparently I was wrong to assume you were using the DTA which you apparently decided against using at that time - sorry about that confusion
So you do not need to post a screen-shot.
As long as you are getting a message alert like you are now and have been for a long time now (you may recall we covered a lot of ground at that time) - so you are good to go.
No worries.
.... good job sportman13.
So then we can consider this topic now closed (as long as you have been getting message alerts all this time since you made you mind up what to use a few months ago).
lakrsrool how would if I wanted to go back to the way your screenshot is ?
sportman13 - all of this has been discussed with you a number of times. You can refer back to some of our more recent discussions on this topic (there have been other discussion we have had on this topic as well but I'll just reference the most currentsportman13 wrote: ↑Sat Sep 12, 2020 5:40 pm lakrsrool how would if I wanted to go back to the way your screenshot is ?
I would suggest you take a look at these two posts in a topic that discussed this subject in part - please refer to the two posts HERE and HERE where this subject was discussed in great detail. This should provide you with plenty of information regarding your question.
That said, you had apparently made a decision previously as to what your Message Alert preferences were back in early May of this year since you have not brought the topic up again since that time.
So I would advise you to continue to use what you finally decided upon at that time (to avoid any more additional confusion going forward
lakrsrool thanks
You are very welcome sportman13.
