Yahoo OAuth2 in PP
Popey
Yahoo OAuth2 in PP
Post by Popey »
I have several old yahoo account, and I tried to set them as recommended in this post But there's no "OAuth2" button.
I tried to get a new portable pop peeper from the site, and set the accounts as new.
There was no option for that OAuth2 part.
I know how it should work from creating an account in Thunderbird, but I am using pop peeper and I want to keep using it after the 20th.
I also tried to install the installation version, but that also didn't help.
Can you help?
OS: Windows 10
Also tried in Windows 7
Re: Yahoo OAuth2 in PP
Take a look at this topic: Yahoo mail changes. If you scroll down through the topic you will find detailed steps (including screen-shot examples) to follow, specifically starting HERE, for both the "Basic" and the "New" versions of Yahoo.
lakrsrool is providing instructions for creating an app-password, which is an alternative but not the same thing as Oauth2 and may or may not always be the best solution.
There are 2 requirements for the Oauth2 button to appear for Yahoo accounts:
1) You must be using IMAP (not POP3 or WebMail)
2) The server must be: imap.mail.yahoo.com
If both of those are true, then you should see the "Oauth2" button.
Popey
Post by Popey »
Thanks Jeff.
The point/ problem was indeed the IMAP part.
I prefer/ use pop all the time, so I didn't have it.
Thank you both.
