keep messages from yahoo groups.
YVONNE
Post by YVONNE »
How do i keep messages from yahoo groups. I have downloaded entire message and turned off PP checking the yahoo server,
Data Path is C:\Users\myusername\AppData\Roaming\POP Peeper
ini C:\Users\myusernameC\AppData\Roaming\POP Peeper\poppeeper.ini
Re: keep messages from yahoo groups.
Hello YVONNE and welcome to the Esumsoft Forums. :)
To get started...a bit more information is needed for us to better assist you. Please post back with the following info:
1. Which version of POP Peeper are you using?
2. Are you also using the POP Peeper Plus Pack?
3. How are you accessing the Yahoo accounts?
(I.e., IMAP, POP3, Webmail)
Other members of The Esumsoft Team will also be reviewing your topic and provide additional feedback.
In the interim, as our newest member, we ask that you please review the following Sticky topic:
Thank you and welcome aboard!
Because Yahoo groups is closing, here's what you can do to keep a local copy of these messages:
Archive the messages
This will store all the messages in standard .eml format which can be opened by most any email client.
1) Under:
main menu: Tools / Options / General
Enable "Advanced options"
and Press OK
2) Right-click on the account in the Account List (left-side of PP) and select "Archive messages"
3) If you have the POP Peeper Plus Pack, you can view these messages via:
main menu: View / Mailbox -> Archive
If you don't have the Plus Pack, you can see the files via:
main menu: View / Explore -> Archive
and double-clicking a file will display it in your registered email client (e.g. POP Peeper)
Backup the database
Make a backup of the database so that in case something happens to your original, you can easily restore it so that you can have the messages back in PP:
1) Under:
main menu: Tools / Options / Storage
2) Double-click the words "data path" -- this will open File Explorer
3) In File Explorer, you'll see a folder with the name of each of your accounts, open the folder that corresponds to your Yahoo Groups account
4) Select the file named data.db (or just "data" if you're not showing file extensions) and copy (Ctrl+C) and paste (Ctrl+V) to make a backup
5) Optionally move that file somewhere for permanent backup
YVONNE
Post by YVONNE »
Thanks Jeff that is what I wanted
