Re-sending (Sending a Copy) of a Message
ronw
Post by ronw »
Is there a way to re-send (send a copy of) a message previously sent? I thought I did it once before in POP Peeper but can't find it now, and I don't see anything in Help or in the forum.
Ron
Re: Re-sending (Sending a Copy) of a Message
Hi Ron,
What you want to do is review the information for the Sent Mail Viewer in POP Peeper's Help Files. The Sent Mail Viewer is part of the Plus Pack which I believe you have.
The excerpt below is taken from POP Peeper's Help Files for the Sent Mail Viewer:
..."POP Peeper must be set to save sent messages. This option is on the main menu, under SendMail / Settings -- "Save sent messages to disk" must be enabled (default).
• If you need to re-send a message: view the message and then select Message / Edit as New from the menu..."
Cheers! :mrgreen:
Here is the link to the Sent Mail Viewer plugin component of the Plus Pack premium add-on.
ronw
Post by ronw »
Thanks, spc3rd and lakrsrool. I already had the Sent Mail Viewer installed, so it was just a matter of getting to Message / Edit as New.
Ron
