Registering POP Peeper as mailto: default
nut
Post by nut »
Is it possible to register POP Peeper as the default for mailto: URLs under Windows 10? POP Peeper does not appear as an option in Windows 10's "Default apps", so presumably I need to edit the registry to accomplish this.
I've actually started down that road but have not yet rebooted to see if my efforts will be met with success, and figured I would ask for advice or if someone has created a REG file that could be imported to accomplish this.
Re: Registering POP Peeper as mailto: default
There is a built-in option --
main menu: Tools / Options
'General' page
"Register POP Peeper as Windows Email client"
You'll then need to set the default Email app to POP Peeper, but POP Peeper will open the appropriate Windows Settings page for you to do so after ticking the above option.
nut
Post by nut »
I've probably seen that before. If so, I totally forgot. I apologize. I'm an asshole.
Thank you.
