Pop Pepper Pro "sent email"
drummond52
Post by drummond52 »
I have pop peeper pro, I can create a new email to send, but I cant find my sent email. any help would be great.
drummond
Re: Pop Pepper Pro "sent email"
If you are asking about viewing your sent mail via PP then take a look at THIS PAGE (scroll down to where you will find a "Comparison Chart") where you will see that the "Sent Mail Viewer" feature is available in the optional "Plus Pack". However, if you are asking about observing sent messages the Email Clients "Sent folder" (not PP) then if you are using the IMAP protocol in PP you should be able to view your sent messages in the Email Client (i.e. the accounts "Sent Folder").
drummond52
Thank you for the reply, I did not realize I needed the plus pack, which I just purchased. thank you and close subject please.
drummond
You can also view Sent Email that's saved in the folder on the server with Pro and/or the Plus Pack:
https://www.esumsoft.com/products/pop-p ... op_folders
