Images
JeanP
Images
Post by JeanP »
I receive a daily newsletter, which includes images. These don't appear anymore (since the last version of PopPeeper I think) ...
...while they do appear in Thunderbird.
Here is my setting for incoming mail.
Did I miss something?
Thank you for your answer.
Re: Images
Try clicking on "Confirm Legit" to see if this helps:
JeanP
Re: Images
Post by JeanP »
No change mjs (even after closing and reopening)
Re: Images
To provide us with more information about your POP Peeper installation - please perform the following steps:
1) From the POP Peeper main menu please go to "File" > "Error Overview..." that will open an empty "Error Overview" window.
2) Click on the "Copy Log" button of the "Error Overview" window - you will get the dialog as illustrated in the screen-shot (below):
3) Click on the "OK" button of the "POP Peeper Log" Dialog Window.
4) Click on the "Close" button to Close the initial "Error Overview" Window.
5) Post the copied information (Status Log) in this topic (by doing a right-click in your post to get a context menu and click on "Paste").
This will paste a "Status Log" in your forum topic that will help us to know more about your POP Peeper install.
JeanP
Re: Images
Post by JeanP »
Here it is:
OS: Windows 8.1 (x64)
POP Peeper: 5.1.2.0
Webmail: 5.1.0.0
SSL: 1.1.1.7
IMAP: 5.1.2.0
SendMail: 5.1.2.0
Notification Skin: 5.0.0.0
AntiJunk: 5.1.2.0
PPTweaker: 5.1.2.0
Sent Mail Viewer: 5.0.0.0
PPbackup: 5.0.0.0
PPextras: 5.0.0.0
Updater: 1.0.0.0
Data folder: C:\Users\JEAN\AppData\Roaming\POP Peeper\
(none)
Re: Images
Does this affect all images in email, or is it perhaps just from a certain sender (ie. that specific newsletter)?
Can you send a sample message that exhibits this behavior? Do NOT post this sample message in the forum.
1) View the message in POP Peeper
2) From the menu, select File / Save message as, and save the file to disk
3) Send this file as an attachment to (support at esumsoft dot com), and please include a brief description of the problem and a link to this forum topic.
JeanP
Re: Images
Post by JeanP »
Hi Jeff,
At first glance, this only happens with this newsletter.
For other posts, either I see the images directly or I get a yellow banner saying that the images are blocked and that I have to double click:
Thank you.
