Status Bar Icons Re-scaling
Moshe
Post by Moshe »
I'm using custom status bar 13x13 images.
The Error image is re-scaled to 14x14. Is that intentional? And the different background color?
Windows 10, default DPI (96).
Thank you.
Re: Status Bar Icons Re-scaling
The suggested image size for that icon is 24x24:
https://www.esumsoft.com/products/pop-p ... s/#buttons
which means that it will usually be downscaled.
If you don't want the image to appear upscaled, then you should make your image size larger and fill in background so that your original graphic is still the same size.
The yellow background is intentional -- too many people over the years have not realized that there's an error. But it only highlights in yellow when there have been 3 (by default) consecutive errors.
Moshe
Post by Moshe »
Hello Jeff,
416 and 418 are NOT re-scaled. I'm using 13x13 images and they are displayed "as-is".
A workaround for 421: a 15x15 canvas size, and 13x13 actual-image.
Thank you.
