Chromebook
crabboy
Chromebook
Post by crabboy »
Any way to run Pop Peeper on Chrome OS?
Re: Chromebook
If you can run WINE on Chromebook, then you should be in business.
crabboy
Re: Chromebook
Post by crabboy »
Old Chromebook, cannot add linux, therefore cannot add Wine. Out of luck?
Re: Chromebook
ChromeOS is based on Linux, that's the only reason I mentioned it; I have no personal experience with ChromeOS, so I don't know for certain that it's possible to install WINE, but there are search results that certainly suggest that it is, e.g.
https://www.reddit.com/r/chromeos/comme ... chrome_os/
That also suggests that CrossOver is available (which I've always associated more with MacOS), which is similar to wine.
