How to change message Junk weight to '10'
amitt1020
Post by amitt1020 »
What is the correct procedure in changing the weight of a single message received. Can I highlight several messages and mark them all at once to a higher weight?
Re: How to change message Junk weight to '10'
You cannot adjust the weight of a message when marking it as Junk. I can kind of see why you'd want to do that, but it shouldn't be necessary and it's not relevant in the long-run. (Technically, you could do it by using the "Train Bayesian (bulk)" in the AntiJunk settings, but I would discourage you from doing this).
Let me ask you to provide some information, so that I have some background info on your situation:
1) From the main menu, select: Tools / AntiJunk -> Main interface
2) Select "Bayesian" on the left
3) On the right, there's "Training data" -- how many Junk and Legit messages does it list there (separately)? Or, if you want to include a screenshot of that page, that may help, too, as there's other interesting stats on that page.
