export/import junk filters
lian
Post by lian »
Hello, is there a method to export/import junk filters so I can share my settings to another computer ?
Windows 10 64 bits
Re: export/import junk filters
There are 2 methods:
1) Simply copy AntiJunk.db from one computer to the other. The location of this file is under:
main menu: Tools / Options / Storage
and refer to the "Data path" value
- make sure that POP Peeper is not running on both sides when you copy the file (more important on the "overwrite" side).
2) There is an import/export, but the above method is easier and will include more data (statistics, etc.); import/export allows you to export select data, or it allows you to import data into an already existing setup.
main menu: Tools / AntiJunk -> Main interface
From the AntiJunk menu: File / Export
lian
Post by lian »
Windows 10 64 bits
