Disabling autocheck does one check on startup
ppuser
Post by ppuser »
Even though i have AutoCheck disabled (default timer set to 0 in options and is 0 in accounts), when the program starts, the popup notification window appears in forming me of new mails. It shouldn't, right?
Re: Disabling autocheck does one check on startup
When I tested for this (exited POP Peeper and restarted POP Peeper) with (Mail Check) polling set to "0" this did not occur in my case.
Does this happen every time you start POP Peeper (with Mail Check polling set to "0")?
When POP Peeper starts-up, what do you see in the POP Peeper status bar (banner at the bottom of the main POP Peeper Interface)?
You should see what is depicted in the screen-shot below (signifying "AutoCheck is disabled"):
Click on scree-shot image to enlarge for better readability (to return to topic, use browser back-arrow)<br />POP Peeper status bar after starting POP Peeper with Polling for messages set to &quot;0&quot;.
POP Peeper status bar after starting POP Peeper with Polling for messages set to "0".
There is another option to check at startup under main menu: Tools / Options / Mail Check.
"Scheduled" mail checks can occur when Auto-Check is otherwise disabled, so if you don't want this, set:
"when POP Peeper starts" = "Do not check mail immediately"
ppuser
Post by ppuser »
2 Jeff: Thanks for the pointer. I'll check it on Tuesday when i'll be at the specific PC where i faced the problem. I think though that its set to "Check mail after delay". Could this be causing that behavior?
Yes, that's still considered a "scheduled" mail-check so it will trigger if auto-check is disabled.
ppuser
Post by ppuser »
OK then, i'll check it and post the results here on Tuesday.
ppuser
Post by ppuser »
Jeff wrote: Fri Apr 29, 2022 2:45 pm Yes, that's still considered a "scheduled" mail-check so it will trigger if auto-check is disabled.
Yup, that did the trick. I changed it and it stopped auto-checking on startup.
