Personalized colors do not work on accounts
frenchlab47
Post by frenchlab47 »
I have several email accounts, and standard colors are too similar to distinguish them. When I select an other color as "yellow" it has no effect on the display. (V 5.4.1)
This function was working well with the old versions.
Thank you for your improvements.
Re: Personalized colors do not work on accounts
There are no known issues with account colors. Can you provide a screenshot as an example? Be sure to mask any sensitive information as this is a public forum; otherwise, send the attachment to (support at esumsoft dot com) and include a description of the problem.
Also, what was the previous version that you were using?
