Cannot connect to SMTP server
Windows 10 pc with latest PP fully updated with a permanent wifi connection.
Here is my weird situation:
One of my email accounts is a business POP3 account and works perfect except when trying to send an email I get an error message that it cannot connect to the SMTP server (netfirms).
When I switch wifi networks (same router) PP is able to send out emails for a short period of time and then gives me again the SMTP server error message. Switching the account to IMAP makes no difference.
PP is allowed through Avast One and Windows firewall and port 587 is open on the router. So any time I have to send out an email (or reply to one) I have to switch networks.
Note that I don't have this problem when I use the same email account through my Android phone (same wifi network).
Hotmail accounts don't have this problem.
Any ideas?
Any ideas?
Re: Cannot connect to SMTP server
That does seem strange. I'm guessing it has less to do with switching wifi network and more to do with Windows resetting something in the wifi that "fixes" it. Here's a few suggestions that I would try:
1) Restart Windows
2) Check if your email provider supports SSL on port 465 instead of STARTTLS (port 587). In PP, edit the account, go to Send Mail and change the top-right dropdown to SSL/TLS.
3) Disable email scanning in your AV. This is usually separate from simply disabling real-time scanning; you'll have to go into Avast settings and disable the email module (temporarily).
If none of that helps:
1) Did this problem start out of the blue or did anything relevant you can think of change?
2) Does it work if you exit/restart PP instead of changing the wifi?
1) Restart Windows
In regards to (step 3 above) disabling the Avast "Mail Shield" (to temporarily test sending messages) -- you might get better results accessing the "Mail Shield" at the Internal "Core Shields" level (Interface) as opposed to disabling "Shields" in general via the Avast tray icon (we have found that, in some cases anyway, disabling the "Email Shield" via the tray icon doesn't always get the results we expect). Note: disabling (unchecking) just the "Scan outbound emails (SMTP)" option (within the "Mail Shield" settings) might suffice, if not however then (temporarily) disabling the Core "Mail Shield" itself (by unchecking the "Enable Mail Shield" option) would be necessary.
Same situation after disabling the Avast "Mail Shield".
Restarting Pop Peeper didn't make any difference.
Same email was successfully sent using a web browser but not through Pop Peeper.
Email provider (netfirms) does not support SSL on port 465 so I am using NO SSL on port 587.
I can send emails only if I change networks.
More problems now. Two of my Hotmail account gives me an error ( the same) when sending. This time changing networks won't resolve the problem.
Please see picture and log below:
POP Peeper: 5.4.5.0
Webmail: 5.1.0.0
SSL: 1.1.1.19
IMAP: 5.4.5.0
SendMail: 5.4.5.0
Profile Picture: 5.4.5.0
AntiJunk: 5.4.5.0
Spell Checker: 5.4.5.0
Trusted Sites: 5.4.5.0
PPTweaker: 5.4.5.0
Updater: 1.0.0.0
Ini file: C:\Users\Spiro\AppData\Roaming\POP Peeper\poppeeper.ini
Data folder: C:\Users\Spiro\AppData\Roaming\POP Peeper\
Spiro [1000: IMAP] ['imap.outlook.com' (993) SSL: 1] [Smtp: 'smtp-mail.outlook.com' (587) SSL: 2] [oauth: 1] [consec: 16]
- Send Mail: Login Error: Auth XOAUTH2
Server Returned: 5.7.3 Authentication unsuccessful [CH0PR03CA0196.namprd03.prod.outlook.com 2023-02-11T15:46:57.881Z 08DB0BFEA0E9EFFA] (#535)
POP Peeper: 5.4.5.0
Webmail: 5.1.0.0
SSL: 1.1.1.19
IMAP: 5.4.5.0
SendMail: 5.4.5.0
AntiJunk: 5.4.5.0
PPTweaker: 5.4.5.0
Updater: 1.0.0.0
- Attachments
- Untitled.png (7.77 KiB) Viewed 26195 times
This error is due to a current problem with Outlook’s SMTP servers.
Please use the password method instead of Oauth2 -- for details see: Outlook SMTP Oauth2 error.
Thank you mjs. Problem with the Hotmail accounts is solved. But the POP3 account still gives me an error.
Very frustrating since this is a business account and cannot reply to customers.
And you had already formerly tried STARTTLS using port 587 (for "Send Mail" settings on the POP3 account) - right?
Has anything you know of changed as of the time the issue started with your POP3 account? (i.e. security software updates or changes that might possibly be contributing to the issue)
Have you tried rebooting the computer?
Please post (in this topic) the specific error you get with the POP3 account (like you did for the Hotmail errors).
I rebooted the computer and the router several times. I even updated the wifi adapter driver. No luck.
This is the error it gives me using NO SSL port 587 And this is the error I get when using STARTTLS port 587 No security software updates or other changes happened that I recall.
It's possible that the server does support STARTTLS if it got to that error. Do you have a personal domain? If so, that may explain the error; there's multiple reasons why, but you can try setting an exception for the host (this isn't something I would always recommend, but it's significantly better than not using SSL at all):
1) PP main menu: Tools / PPtweaker
2) Select the "certificates" page on the left
3) In the edit box, add your SMTP host (e.g. smtp.domain.com)
4) Press OK and test sending (make sure that your SMTP account is using STARTTLS and also make sure that it's in a working state)
Now, something that's interesting here -- Your "no ssl" prompt suggests it couldn't connect. But your "starttls" error suggests that it *did* connect -- it has to connect in order to even attempt the TLS socket connection.
My guess is you have some security software (maybe even Windows itself) blocking unencrypted connections on port 587. Have you noticed a pattern? ie. you're able to send one message unencrypted, but the next time it fails?
Nothing helps...
I experimented with PP a lot, I even unchecked the SSL verification button hoping to instruct it NOT to check for a verification. I paused Malwarebytes, Avast, Windows Firewall.
Nothing...
The funny thing is that if I wait a few minutes PP sometimes sends the messages meaning that it connects to the server as long as they are not marked as "suspended" in the outbox status.
I am leaning towards it is PP's fault. Do you think re-installing it might help?
Nothing...
If it was PP's fault, then I would expect exiting/restarting to fix it, and you said that didn't work. If it's intermittent, then that also suggests that the problem is probably on the server's end.
If you have a corrupt program file, then re-installing might help. You can look under Help / About and check the "CRC" for any failures. Regardless, you can try re-installing either way, it won't hurt anything.
The only other thing I can think of to do at this point -- if you're willing to create a (temporary) email account on your server, I can experiment with it and see if I can (a) get TLS to work and (b) see if I have any issues. If so, email me (support at esumsoft dot com).
Jeff,
Thank you for all your efforts to help me. Great support.
Please look at my CRC below: I just re-installed PP. Same situation.
I emailed you with the temporary account info.
I'm sorry, but I do have the same problem. This is what Pop peeper say about it:
Marjaswebsandbox (consecutive errors:80)
unknown provider
POP Peeper: 5.5.1.0
Webmail: 5.1.0.0
SSL: 3.0.13.0
IMAP: 5.5.1.0
RSS: 5.4.5.0
SendMail: 5.5.1.0
Notification Voice: 5.4.5.0
Profile Picture: 5.5.1.0
AntiJunk: 5.5.1.0
Spell Checker: 5.5.1.0
Trusted Sites: 5.5.1.0
PPTweaker: 5.5.1.0
Sent Mail Viewer: 5.4.5.0
PPbackup: 5.4.5.0
PPextras: 5.4.5.0
Updater: 1.0.0.0
Ini file: C:\Users\ympkw\AppData\Roaming\POP Peeper\poppeeper.ini
Data folder: C:\Users\ympkw\AppData\Roaming\POP Peeper\
--- Web Test ---
Result: 200
Error:
Time: 10:35:27 - 10:35:27 (0 s) (+0200)
Data: Fri, 28 Jun 2024 01:35:26 -0700
Marjaswebsandbox [0: POP3] ['mail.mail.marjaswebsandbox.nl' (995) SSL: 0] [Smtp: 'mail.marjaswebsandbox.nl' (587) SSL: 1] [oauth: 0] [consec: 1]
- Onbekende provider
Marjaswebsandbox is my own website, located at Ccchosting.nl
Can you please help me out of this?
Regards,
Marja (Dutchy)
unknown provider
POP Peeper: 5.5.1.0
Webmail: 5.1.0.0
SSL: 3.0.13.0
IMAP: 5.5.1.0
RSS: 5.4.5.0
SendMail: 5.5.1.0
AntiJunk: 5.5.1.0
PPTweaker: 5.5.1.0
PPbackup: 5.4.5.0
PPextras: 5.4.5.0
Updater: 1.0.0.0
--- Web Test ---
Result: 200
Error:
Regards,
Marja (Dutchy)
I see a few issues:
1) you have 'mail.mail.marjaswebsandbox.nl' -- an extra 'mail.', try instead:
2) You're not using any SSL on port 995. Try changing to "SSL/TLS".
3) On the "Send Mail" page, you have SSL on port 587, which is also usually not correct, try changing to STARTTLS.
Some of these values are based on educated guessing -- I'm assuming you read a guide that told you to change the port, but didn't tell you to change the SSL type. So these SSL changes are based on the ports that you're using, instead of the SSL settings you have.
Jeff thank you for your answer. I did change all the items you adviced. But unfortunately, it didn't work. this was the result:
POP Peeper: 5.5.1.0
Webmail: 5.1.0.0
SSL: 3.0.13.0
IMAP: 5.5.1.0
RSS: 5.4.5.0
SendMail: 5.5.1.0
AntiJunk: 5.5.1.0
PPTweaker: 5.5.1.0
PPbackup: 5.4.5.0
PPextras: 5.4.5.0
Updater: 1.0.0.0
Marjaswebsandbox [0: POP3] ['mail.marjaswebsandbox.nl' (995) SSL: 1] [Smtp: 'mail.marjaswebsandbox.nl' (587) SSL: 2] [oauth: 0] [consec: 3]
- SSL verbinding mislukt (is SSL plugin geladen?) - certificate failed: Specified server does not match hostname in certificate [hostname mismatch] https://www.esumsoft.com/ppfaq?q=error_ ... memismatch Add exception: pp://AddSslException?mail.marjaswebsandbox.nl
It's funny, this emailaddress does work perfect in Outlook, but not in Pop peeper. Although Outlook had to recover the address, but I can't see what have been changed by Outlook.
Regards,
Marja
POP Peeper: 5.5.1.0
Webmail: 5.1.0.0
SSL: 3.0.13.0
IMAP: 5.5.1.0
RSS: 5.4.5.0
SendMail: 5.5.1.0
AntiJunk: 5.5.1.0
PPTweaker: 5.5.1.0
PPbackup: 5.4.5.0
PPextras: 5.4.5.0
Updater: 1.0.0.0
Regards,
Marja
This is a typical error for personal domains that are on a shared/VPS hosting service. You have a few choices:
1) Update the server with the one that your host recommends. e.g. if your provider is webhost.com, then it's usually mail.webhost.com, but you should check with your provider's documentation.
2) Similar to above, but this method allows you to still use your own host name, and still get the benefits of the security check; this is the method that I personally use:
a) From POP Peeper's main menu, select Tools / PPtweaker
b) Select the "Certificates" page
c) Add a line that includes *your* mail domain, followed by a space and then the actual webhost's mail server, e.g.
mail.marjaswebsandbox.nl mail.yourwebhost.nl
3) Add an exception using the link in the error (from within POP Peeper). Even though this is the option provided by POP Peeper, it's not recommended as it's the least secure method.
It's unlikely that Outlook would work without a similar solution; it would negate one of the main functions of an SSL certificate. ie. proving that the server you're connected to is actually the server that you think you're connecting to.
