Give error after last SSL install..
Lara
Post by Lara »
Give error after last SSL install, u can see it in the screenshot..
Probably there was a bad update and please go to solution for this error, OK?
Your information, thanks.
Re: Give error after last SSL install..
I haven't heard any other issues; and I personally used this SSL for about a week before releasing it.
What method did you use to install this version? (ie. auto-update, exe installer, zip installer...)
You might want to try re-installing POP Peeper (which should re-download the SSL files, if you use the exe installer):
https://www.esumsoft.com/download/?prod=pppro
Or just re-install the SSL files:
https://www.esumsoft.com/pop-peeper/plugins/#SSL
