Move PP to a new Account on same machine
jdbliss
Post by jdbliss »
Is there a simple way to move my PP instance from my original User Account on my w11 machine to a new User Account on the same machine? I needed to create a new account because of an error in another program, so am moving everything over to the new account. PP doesn't show up in my start menu.
I am thinking I just reinstall and then move this folder to my new profile:
C:\Users\<original account>\AppData\Roaming\POP Peeper
Any advise on this? Thanks!
Re: Move PP to a new Account on same machine
Yes, that should do it. Make sure that POP Peeper is not running when you move the appdata files.
It's not entirely necessary to re-install POP Peeper, you can just go to C:\Program Files (x86)\POP Peeper\ and run POPPeeper.exe (after moving the appdata files). But if you want the icons in the start menu, then re-installing is the way to go.
But in either case, when you run POP Peeper, you'll need to go back into Tools / Options / General and tick the box for "run at windows startup". Also re-enable "Register POP Peeper as windows email client" on the same page if you had that enabled before. These are both per-(Windows-)user settings so they need to be re-applied for the current Windows user.
jdbliss
Post by jdbliss »
Thanks Jeff, much appreciated!
