None of my Outlook accounts are working.
Styx
Post by Styx »
I can log on to all of them manually but poppeeper last would do so on July 16.
Ideas?
Thanks!
Styx
Re: None of my Outlook accounts are working.
Post by Styx »
Just found the answer... I had updated the SSL when prompted the other day.
Had to go into all Outlook Accounts and reset StartTLS to SSL/TSL and they all work now.
Glad you found the solution.
I'm not sure why updating the SSL plugin would have caused that. I have a couple outlook accounts myself and I haven't heard anyone else report a similar problem.
That being said, I tested and confirmed that Outlook with StartTls doesn't work. That despite the server explicitly stating that it does support it:
[11:22:08 07/19] [Outlook] {Connect/IMAP} ----- 'imap.outlook.com:143'
[11:22:08 07/19] [Outlook] {Recv} (160) '* OK The Microsoft Exchange IMAP4 service is ready.'
[11:22:08 07/19] [Outlook] {Send} (-1) 'a CAPABILITY'
[11:22:08 07/19] [Outlook] {Recv} (142) '* CAPABILITY IMAP4 IMAP4rev1 LOGINDISABLED STARTTLS SASL-IR UIDPLUS ID UNSELECT CHILDREN IDLE NAMESPACE LITERAL+'
