oauth2 problems
lian
oauth2 problems
Post by lian »
Today, I have a lot of problems connecting to GMail. PopPeeper asks for another authorization. It works a short period and stops working.
POP Peeper: 5.4.6.0
Webmail: 5.1.0.0
SSL: 1.1.1.23
IMAP: 5.4.6.0
RSS: 5.4.5.0
SendMail: 5.4.6.0
Notification Skin: 5.2.0.0
Notification Voice: 5.4.5.0 (disabled)
Profile Picture: 5.4.6.0
AntiJunk: 5.4.6.0
Spell Checker: 5.4.6.0
Trusted Sites: 5.4.6.0
PPTweaker: 5.4.6.0
Sent Mail Viewer: 5.4.5.0
PPbackup: 5.4.5.0
PPextras: 5.4.5.0
Updater: 1.0.0.0
Ini file: C:\Users\Seven\AppData\Roaming\POP Peeper\poppeeper.ini
Data folder: C:\Users\Seven\AppData\Roaming\POP Peeper\
Gmail lian00 [0: POP3] ['pop.gmail.com' (995) SSL: 1] [Smtp: 'smtp.gmail.com' (465) SSL: 1] [oauth: 0] [consec: 6]
- Login Error ([AUTH] Application-specific password required: https://support.google.com/accounts/answer/185833) Edit account: pp://EditAccount?R21haWwgbGlhbjAw
Windows 10 64 bits
Re: oauth2 problems
Here are a few suggestions:
Note that your error suggests you are not using Oauth2, despite the subject of your post. I presume that you have tried Oauth2, but at the time you captured this error, you were trying other things.
1) Try using IMAP instead of POP3
2) To use password method, you must create and use an app-password. Use the link provided in the error for information.
3) Just wait; some people seem to have issues with gmail rejecting their oauth credentials but it should eventually clear up. And I recommend not trying to force it when this happens as this may exacerbate the situation.
lian
Re: oauth2 problems
Post by lian »
I did not know about the password and app thing. Thanks. It works.
Windows 10 64 bits
