With Gmail shutting down Oauth2 for POP Peeper (as first announced here), here is a list of your available options to continue accessing your gmail accounts:
1) As of this writing (April 30), Gmail accounts continue to work with POP Peeper's Oauth2. If you need to reset your Oauth2 credentials, there's a "backdoor" method to do this for POP Peeper v5.6.x--
Hold down F8 when you "Edit" the account in POP Peeper and the "Oauth2" option will be available;
e.g. select the account in the Accounts List, then hold down F8 while pressing F2 (F2 is the default "edit account" shortcut)
-> An existing password will override Oauth2, so make sure you delete any password you have entered
2) If you don't want to enable 2FA for all your accounts (which is a requirement for app-passwords, below), then you can use personal Oauth2 credentials. Note: Google has announced that in the near future (May 12, 2025), the account that you set this up on will require 2FA. There are some work-arounds to this requirement mentioned in the guide, so I wouldn't let this affect your decision too much.
-> If you don't want to enable 2FA on all your accounts, this is the recommended solution.
Using personal Oauth2 credentials
3) Use an app-password. The biggest hurdle for this method is that each account using an app-password must enable 2FA.
-> If your Gmail accounts already have 2FA enabled, this method might be the easiest.
Creating app-passwords
This guide is a work-in-progress and will be updated as necessary.
