So I am posting it here, maybe someone else has the same issues.
Code: Select all
OS: Windows 11 (x64)
POP Peeper: 5.6.3.0
Webmail: 5.1.0.0 (disabled)
SSL: 3.0.16.1
IMAP: 5.6.3.0
SendMail: 5.6.3.0
Profile Picture: 5.6.3.0 (disabled)
AntiJunk: 5.6.3.0 (disabled)
Spell Checker: 5.6.3.0
Trusted Sites: 5.6.3.0 (disabled)
PPTweaker: 5.6.3.0
Updater: 1.0.0.0
Program folder: F:\***
Ini file: F:\***
Data folder: F:\***
Outlook - *** [1000: IMAP] ['outlook.office365.com' (993) SSL: 1] [Smtp: 'smtp.office365.com' (587) SSL: 2] [oauth: 1] [consec: 5] [enabled: 1]
- Oauth2 error -- There was a problem connecting to the Oauth2 server. Try again later or reset Oauth2 if the problem persists. Reset Oauth2: pp://OAuth2?***= Edit account: pp://EditAccount?***=
I have some Outlook accounts and all work well, until "suddenly" the authorization stops working (and the above error messages pop up).
Sometimes 1 out of 3 accounts does this, sometimes all and when the work... they just work. In between I do not do anything else with settings or something.
When I wait (sometimes for hours) the error disappear and when I turn of the internet (disabling my router) or switching to another network (from LAN to WiFi) the problem CAN be solved... untit it starts hunting me.
The weird thing is, when I "reset" the oAuth Pop Peeper freezes like this;
1. Click on "reset" oAuth
2. Window is shown with the 3 options (web/ form/ inline code)
3. Browser opens (with Outlook oAuth page)
4. All is authorized, browser returns to Pop Peeper (with screen 2.)
5. Pop Peeper freezes; nothing works, wait for a minute or two
6. Pop Peeper comes alive, telling me "oAuth failed" (which did)
Like I said, when I wait for a while, sometimes hours, leaving my computer "on" and continue with my work, it all starts working again like magic.
Weird, he!
BTW. There was a problem connecting to the Oauth2 server can be true (maybe something is blocking it at random intervals?) but when I hit 'authorize' I can connect to the server without problems (in the browser).
O, and none of the three options does work: they all freeze with the same error-message after some time.
