AOL send mail
mielu
AOL send mail
Post by mielu »
I read the topic about Aol and I'm using FreePOPs to get the mesahes from
aol account,
My question is if I can send mail using poppepet and if yes
can you tell me what settings need to be done
Tahnk you
war1
Post by war1 »
Freepops only provides a gateway between AOL and your email client for POP3 receiving access. It does not provide SMTP access for sending.
You should use Pop Peeper newest version 3.0 RC, as it allows you IMAP access. Since AOL allows you IMAP access, you can use PP with AOL.
Warren
If mielu wants to continue using v2.4 (presumably), you could still setup PP to use AOL's smtp server.
- Edit the account
- Select the "Send Mail" tab
- Change "Reply Options" to 'SMTP'
- SMTP Server: smtp.aol.com
Note, some smtp servers require you to check incoming mail first. I don't know if AOL is like that, but it may cause problems for you since FreePops won't be checking your incoming mail using a traditional method.
But, it is true that PP v3.0 supports Imap and Aol will work without having to use FreePops.
mielu
thank you
Post by mielu »
thank you for informations
it was really helpfully
mielu
just one thing
Post by mielu »
i thought i could download the v3.0 from the home page
but it's not there can you tell me if it can be downloaded from
anywere?
war1
Re: just one thing
Post by war1 »
mielu wrote:i thought i could download the v3.0 from the home page
anywere?
You can download the new PP from the Announcement forum
http://www.poppeeper.com/Forums/viewtopic.php?t=901
Warren
