Oauth2 error messages
clp6819
Re: Oauth2 error messages
Post by clp6819 »
All I did was uninstall, clear cookies then reinstall so it can't have been anything I did. If I'd realised backing up that folder made reinstalling so easy I'd have done it long ago haha
techmanc
Post by techmanc »
here where I am with aol using Oauth not sure which verizon this my 1st post here the copy and paste no luck trying both methods also when I used the web browser option it never took me to that site
POP Peeper: 5.5.3.0
Webmail: 5.1.0.0
SSL: 3.0.15.0
IMAP: 5.5.3.0
RSS: 5.4.5.0
SendMail: 5.5.3.0
Notification Voice: 5.4.5.0
Profile Picture: 5.5.3.0
AntiJunk: 5.5.3.0
Spell Checker: 5.5.3.0
Trusted Sites: 5.5.3.0
PPTweaker: 5.5.3.0
Sent Mail Viewer: 5.4.5.0
PPbackup: 5.4.5.0
PPextras: 5.4.5.0
Updater: 1.0.0.0
Ini file: C:\Users\Techman\AppData\Roaming\POP Peeper\poppeeper.ini
Data folder: C:\Users\Techman\AppData\Roaming\POP Peeper\
Verizon [1000: IMAP] ['imap.aol.com' (993) SSL: 1] [Smtp: 'smtp.verizon.net' (465) SSL: 1] [oauth: 0] [consec: 3]
- Login Error ([AUTHENTICATIONFAILED] LOGIN Invalid credentials) -- Edit account: pp://EditAccount?VmVyaXpvbg== Tip: Edit the account and enable OAuth2, or use the following link: Set Oauth2: pp://OAuth2?VmVyaXpvbg==
techmanc
Post by techmanc »
I just checked I have PP ok on AOL but I cant get new email btw I cant see any replies using PP I will keep checking replies made to AOL acct I want some reply so I know how to move forward btw I dont have any other ways to get my email no replies atm is PP still viable to get emails checked if not what do you suggest its a pita using PP atm!
Your error shows that Oauth2 is not being used. If you use a password, then you must create a new app password; further, Yahoo has reported that old app passwords may not be valid.
If your webbrowser does not open when trying to authenticate Oauth2, then you should set a different browser --
From PP's main menu: Tools / PPtweaker
"Misc 2" page
Change the "browser to launch URLs"
techmanc
Post by techmanc »
When I clicked the broswer it did not work now I can get the AOL site and its working TIA!
clp6819
Post by clp6819 »
I have an update. The errors started again and I think it's an IP issue. I disabled my ethernet connection to my main Starlink connection and connected by WiFi to my backup 4G connection and the software works without issue. I am due to get a fibre connection (FTTP) soon so hopefully getting rid of Starlink will resolve the issue once and for all.
Interesting. The bigger email providers surely do keep track of "dirty" IP addresses, which could have temporary effects, but you'd think that once it started working again, you'd be good for a while (longer than a day or two). Good luck with the new connection and let us know if it continues to work or not.
clp6819
Post by clp6819 »
Just wanted to update again to confirm that the issues I encountered must have been IP related because since I stopped using Starlink IP (a week ago) I have not experienced any issues whatsoever.
Glad to hear it!
