CZECH translation
chmel
CZECH translation
Post by chmel »
I already started, but your string table is terrible long... :shock: :?
Hustey
CZ a PPTweaker
Post by Hustey »
Asi mi admin nebude rozumet, ale jednou tady je "czechtranslation", tak by se tady mohlo mluvi cesky... :)
Mam POP Peeperera jiz dlouho a musim rici, ze je ve sve tride absolutni jednicka a to jsem jiz takovych notifikatoru vyzkousel celou radu. Kazdopadne by me zajimalo, jestli nekdo vite?
1. jestli nekdo nekdy prelozí PPTweaker?
2.jestli lze pouzit ve v3.0 starou verzy PPT na backup(zalohovani) a obnovu(restote), protoze v novem pluginu tato verze neni.
Tak sem vsichnu hura piste! Tesim se na vsechny Vase reakce.
Ahoj
Hustey [CZ]
8) 8) 8)
Hustey
Pop Peeper
Post by Hustey »
Jakou mate zkusenost s tim, kdyz date PP stahovat vsechny zpravy na disk s rychlosti? Me se totiz pak otvira strasne dlouho :( jede to na P4 3GHz-1G casch-1GB RAM..
Coz me tedy dost stve.
Huy
:idea:
Hustey
Re: Pop Peeper
Post by Hustey »
Hustey wrote:Jakou mate zkusenost s tim, kdyz date PP stahovat vsechny zpravy na disk s rychlosti? Me se totiz pak otvira strasne dlouho :( jede to na P4 3GHz-1G casch-1GB RAM..
Huy
:idea:
Tak pro ty, ktere to zajima, uz jsem to tady na foru nasel. Cesta: C:\Documents and Settings\Administrator\Data aplikací\POP Peeper- zde se nove objevil soubor poppeeper.ini, který si proste nakam zazalohujete+dalsi data spolecne. :D
Jednoduché a proste... :D
Enjoy
Hiya Hustey... any chance you or someone else can translate this to English? No online translator I know of supports Czech...
Hustey
Post by Hustey »
Thanks. I´m fine :D
Visit PC Translator 2007 http://www.abitz.com/uebersetz/pctransengl.php3 :wink:
Bye
JRF
Post by JRF »
Just to confirm , the PP translation to Czech seems to be not updated to 3.0.1 yet ...
Dreamy
Post by Dreamy »
JRF, I will write slovak translation for PP 3.1, slovak is similar to czech enough. Maybe I will update czech too.
JRF
Post by JRF »
Hi dreamwalker , that is great , your translation to Slovak will complete the modern Slavic languages (we have already for Slovenian -- stated as [v3.0 4 Oct 17, 2006] ?? ) .
Ref. your offer to update the Czech flavor , I would suggest you first contact/inquiry chmel (the 1st post up here) , I guess he was the translator .
Dreamy
Post by Dreamy »
Well, I wrote a pm to Chmel and a mail to Hustey too. I never
thought that you are working on a language collection. ))
I wrote my personal slovak translation for PP 2 but since that,
I used czech and now I'm using simply english. I'm not mardy
so I use any language available. I speak many languages, too.
Hustey
Post by Hustey »
To: DreamWalker
Tak to doslo asi k nejake mylce, nedelam na prelozeni, nebot preklad pro verzi v3.0 od Marek Hron http://data.poppeeper.com/Languages30/Czech.plf funguje i ve verzi 3.0.1.0 naprosto dokonale... :wink: a navic znam i docela dost lidicek co PP pouzivaji k naproste spokojenosti.
Jen jem myslel, ze by se tady nekdo chytil na czech block a napsal nejake sve zkusenosti s PP.
Takze se omlouvam, ze jsem toto napsal do CZECH translation.
Ja ho pouzivam kazdy den a jsem s nim velmi spokojeny a nedokazi si jiz bez nej notifikaci vetsiho mnozstvi schranek predstavit :D
Preji hezky den
Hustey
Dreamy
Post by Dreamy »
Ahoj Hustey!
Dakujem za odpoved. Len som chcel vediet, ci ste este zivi. :)
Mozno by to chcelo rozbehnut nejaku cesku a slovensku podporu
PP, nech viac ludi vie, ze je to fajn program. Ale vsak uvidime.
Kazdopadne som rad, ze tu niekto hovori aspon podobnym jazykom
ako ja. ))) To vzdy potesi.
Hustey
Post by Hustey »
Ahoj dreamwalker, jj je to bezva. Pripravuji take na mem skrovnem foru i nejakou podporu pro POPPeeper :) Mimo jine vim, ze se podilis i na nejakem malem projektu co se tyka QIPu. :o Oba softiky prakticky moje skupina kolem mne pouziva k veseobecne spokojenosti. Takze na forum nahazu jak linky sem, tak na ceske forum qipa.
Zatim se mej fajn.
JRF
Post by JRF »
Well ... I can not say I dissent completely :lol:
Dreamy
Post by Dreamy »
>mem skrovnem foru
Daj link.
Maly projekt? :-D qip.sk
To som rad.
JRF:
Sorry man, it's nothing so interesting to translate, but if you can't hold inquisitiveness, I can translate it for you. ))))
JRF
Post by JRF »
That is ok , I was just joking ... :lol:
(I would however have used any of the other 7 communication options you offer in your sig ... but it is ok ... )
uziv
Re: CZECH translation
Post by uziv »
Mnou upravený překlad pro verzi 3.8.1:
POPPeeper-381-Czech.zip
(12.59 KiB) Downloaded 2464 times
Thanks for the update, uziv.
The update has been posted and is available directly through POP Peeper and on the website:
http://www.poppeeper.com/languages.php
There was very minor issue with a "duplicate & character" in validation -- which just means that a menu has 2 items using the same letter to access them -- which I fixed by removing the ampersand from one of them. If you think you'll make the update for the next version, please download the update I made so that you have this change.
