POP Peeper v3.7 RC
POP Peeper v3.7 RC
A beta / Release Candidate is available for POP Peeper v3.7. If you find any issues in v3.7, please email support immediately.
Download: see post below for newer RC
Some new options have been added to PPTweaker, which can be downloaded here (new options require POP Peeper v3.7):
http://poppeeper.mortaluniverse.com/v37 ... er_v37.zip
v3.7 Changes
- Additional version information presented in webpage when using "download" button
- Option to flash NumLock LED for new message indicator
- Option to open URLs in new browser window added in v3.6 (PPTweaker)
- Option to define the number of consecutive errors that causes error tray icon (PPTweaker)
- Option to prevent attachments from being included in the saved .eml file for sent messages (PPTweaker)
- Enhancement to Ini Manager allows add and delete
- Automatic Ini backup to prevent loss of data when ini file is corrupted
- Error popup if email client cannot be run (Windows 7 does not provide a default email client)
- Run Client for multiple accounts with new mail will open each account's *unique* client
- Fix: Occasional crash under certain conditions when using accounts as Imap/SSL/Idle
- Fix: In certain situations, POP Peeper would show duplicate messages on initial startup
- Fix: Processing extended capabilities after login
- Fix: RFC822 messages containing multiple attachments with same filename (usually images) will all appear
- Fix: SendMail, alert when attempting to send an attachment that does not exist
- Fix: When editing account, pressing update button will alert to missing required fields instead of being disabled
- Fix: PPInfo.txt will be saved to data folder instead of installation folder (UAC issue)
- Fix: Logic for retrieving auto-update info has changed to lighten load on web server
- Fix: RSS, SMTP is not enabled by default when creating a new RSS account
- Fix: SendMail, minimum size constraints for dialog window
Re: POP Peeper v3.7 RC
POP Peeper v3.7 RC2 is now available.
PPTweaker has changed since v3.6, but not since the previous RC1:
Changes since RC1
- SMTP: includes headers for In-Reply-To and References
- Hotmail: Detect Captcha (webmail changes are not documented in revision list)
v3.7 Changes
POP Peeper v3.7 RC3 is now available.
Download:
http://poppeeper.mortaluniverse.com/v37 ... 37_RC3.exe
Changes since RC2
- HtmlRef.dat file updated to include additional Greek characters
- Fix: Imap, TLS is allowed if server supports logindisabled capability
- Fix: If using per-account sounds and retrieving number of messages only, account sound would not play
- Fix: Tooltips added for Outbox buttons (view/delete message)
Changes that affect behavior to features added in v3.7
- Fix for opening attachments, uses actual filename from temp path
- Account's "Update" button only enabled if something changed
v3.7 Changes
