not seing mail from gmail in pop peeper
pluto
Post by pluto »
pop peeper is getting the mail from all the servers except gmail. I am not getting any error messages, everything seems to be working except no visible gmail. this problem exists on two pc's one with XP and the other W7. both have the same problem. this is happening the last week or so.
pluto
Re: not seing mail from gmail in pop peeper
Post by pluto »
reinstalled poppeeper and now showing errors
OS: Windows XP
POP Peeper: 4.0.1.0
Webmail: 4.0.14.0
SSL: 1.0.1.8
IMAP: 4.0.1.0
SendMail: 4.0.1.0
AntiJunk: 4.0.1.0
Spell Checker: 4.0.1.0
Web of Trust: 4.0.1.0
--- Web Test ---
Result: 200
Error:
Time: 18:08:20 - 18:08:21 (1 s) (+0200)
Data: Sun, 26 Jul 2015 09:08:20 -0700
gmail [10: GMail] ['pop.gmail.com' (993) SSL: 1] [Smtp: 'smtp.gmail.com' (465) SSL: 1]
Login Error: Check your Login Name and Password.
gmail jr [10: GMail] ['pop.gmail.com' (993) SSL: 1] [Smtp: 'smtp.gmail.com' (465) SSL: 1]
updated webmail to 4.0.17 did not help, pop peeper not showing errors but is still not getting gmail.
Welcome to the forum pluto, sorry for the delay getting back to you. Now that you've updated the PP webmail plugin to the current (4.0.17.0) version refer to this topic where Jeff posted the following: CLICK HERE. Follow the suggestions posted by Jeff in the » Mon Jul 13, 2015 12:26 pm post where this link takes you at the bottom of the topic page.
It is likely the 1st paragraph or possibly 2nd paragraph will apply in your case but if not read on in this post. If you continue to have issues you may want to continue to read on into Page 2 of the topic in the event this happens to apply in your case.
That said, if the above doesn't help and considering that your using the "webmail" Server-type settings (that is, "Gmail" Protocol) for your Gmail accounts it may be that Gmail has made changes requiring Jeff to update the Webmail plugin once again as was the case before with the most recent Webmail plugin (ver. 4.0.17.0) update that fixed "login errors in GMail" at that time.
Post back if that topic linked above helps or not, if not and your issue persists then let us know as well in which case Jeff should be looking into this tomorrow (July 27th).
pluto
Post by pluto »
logging in and out helped. thanks for the advice.
