Blue blackground making white
Jawade
Post by Jawade »
The messagefield has a lightblue background. I 'd like its white. Is this possible?
Greetings, Jawade
Re: Blue blackground making white
Please see this guide:
http://www.esumsoft.com/products/pop-pe ... listcolors
I just added an alternative to completely disabling it, so you can still get a visual cue when you should train it.
Jawade
Post by Jawade »
Thanks, now I know the reason, it's all right. If I was the programmer, I took a more
pastel color.
Greetings, Jawade
hm, but what colors would a graphic designer use? I am a prime example of why programmers get a bad rep for graphic design :)
The reason I used those colors is because they're very close to white, but tinged with the appropriate color. I plan on doing some experimenting tonight with different colors, especially pastels.
Can you tell me specific examples of what was hard to read (if it was, I guess you didn't actually state that)? That is, what color is the account color? You can change the color yourself, instead of simply disabling it, so if you find a better color scheme, let me know. I am very willing to tweak the default colors...
