Windows 10 X64 Voice Notifier does not work
ruediger
Post by ruediger »
Please help me. The 'Voice Notifier does not work. I get the message: Speech failed with error 2147766330. Contact Tech Support if you are not able to resolve this error.
Re: Windows 10 X64 Voice Notifier does not work
What version of Pop Peeper are you using?
Please go to "Tools" > "Options" > "Notification" tab and post what you see within "Audio" section of the window for the "New Mail" setting (as illustrated below).
New Mail message setting
It's possible that POP Peeper is trying to use a voice that is no longer available on your system. Try this:
1) From POP Peeper's main menu, select Tools / Voice notifier -> Voice notifier settings
2) Select the "notification" page on the left
3) Change the "voice" to the default
4) Press the "test" button to make sure it works
5) If you use the "Reader", be sure to change that voice, too (select the "Reader voice" page on the left)
6) Press OK
