DLL updates (SSL)
w64bit
DLL updates (SSL)
Post by w64bit »
Can libeay32.dll and ssleay32.dll be updated to v1.0.2f (1.0.2.6)?
Thank you
Reason: Updated title to indicate SSL
Re: DLL updates
Sure, download it here:
SSL 102f
Give it a try for a couple days and let me know if you have any problems or not. Anybody else that wants to test it, feel free to do the same.
w64bit
Re: DLL updates
Post by w64bit »
Updated on 17 feb.
All OK until now (no single error).
I think that it's better to add them to the installer and to fix version checking info in About window for columns Latest and CRC.
Thank you
Re: DLL updates
re: crc -- thanks. I had checked the about page on initial test, but I was focused on the version and guess I didn't wait for the CRC to show its result. It's been fixed now and re-uploaded.
re: latest -- This is actually intended behavior. One of these days, I'll implement an auto-update for SSL (like webmail) and this should fix the potential issues.
w64bit
Re: DLL updates
Post by w64bit »
SSL 1.0.2g is released.
w64bit
Re: DLL updates
Post by w64bit »
SSL 1.0.2h is released.
Re: DLL updates
Thanks, I'll try to get it updated soon.
Re: DLL updates
OpenSSL 1.0.2h is now available:
http://www.esumsoft.com/products/pop-pe ... ugins/#SSL
The regular install still points to the previous version until this has been verified further.
Sorry for the delay!
w64bit
Re: DLL updates
Post by w64bit »
1.0.2j is out
Re: DLL updates
In fact, there's a new 1.1 line available now, too. I'll have to do some research to see what's what...
Re: DLL updates (SSL)
I decided to stick with the 1.0.2 line for now. 1.0.2.10 (j) is now available:
Let me know if you have any issues with it.
