My SSL has fallen and can't get up
jjgui1
Post by jjgui1 »
Actually, my SSL has not only fallen, but disappered! :shock:
After a 2nd attempt at upgrading correctly to v4.2, I no longer have this feature when checking "About" in PP - completely removed from the list of features. Two of my accounts, Comcast and Gmail, complain about the missing SSL when trying to login and check mail.
I've poked around the forum and looked for info on how to obtain or update SSL in PP, but so far I am lost. Did I miss something? #-o
No sig here (i don't smoke hehe)
jjgui1
Re: My SSL has fallen and can't get up
Post by jjgui1 »
My SSL has Unfallen. :shock:
The Phoenix has risen from the ashes: http://www.esumsoft.com/products/pop-pe ... ugins/#SSL =D>
(... in case anyone else needs help in locating SSL, the link is listed above)
That is strange -- an update wouldn't remove the files and, by default, PP will install the files if they're not there. Well, unless you used the zip download -- SSL files are not included in that installation. So if you installed to a new/different folder and used the zip installation -- mystery solved :)
jjgui1
Post by jjgui1 »
Unzipped to a fresh folder, I believe (having to think back about it now). #-o
