Yahoo error -11
captqbec
Yahoo error -11
Post by captqbec »
hi all,
...started getting this Yahoo error -11 since this morning.
Changed all my Yahoo passwords...still same error...reboot....still same problem.
Please help
ljrjess69
Re: Yahoo error -11
Post by ljrjess69 »
im having the same problem changed passwords etc and now error code -11 today :(
Re: Yahoo error -11
Yahoo has made some backend changes to the login this morning. It is being worked on -- I'll post more information here when it's available.
Re: Yahoo error -11
WebMail v4.2.5 fixes the Yahoo -11 error. You can either wait for POP Peeper to auto-update (usually within 24 hours) or to update immediately:
From POP Peeper's main menu, select Help / About
Make sure that these 2 options are enabled:
- Automatically check for updates
- Auto-update Webmail plugin
Press the "Check version" button
ljrjess69
Re: Yahoo error -11
Post by ljrjess69 »
worked thanks! :D
captqbec
Re: Yahoo error -11
Post by captqbec »
thx :D
