I try to manage better the spam and put rules to delete automatically spam but I’ve a little problem: it seems impossible to check the spam score of a spam in junk ?
see antispam score for junk files
Windows 10 64 bits
Re: see antispam score for junk files
Perhaps this page might help regarding "junk" mail: http://www.esumsoft.com/products/pop-peeper/pro/, check out the video on that page and continue reading on regarding "AntiJunk" below the video.
Th Junk View icon is the solution. I will look carefully at the video. As I’m french, it’s not easy to understand the help file for this feature - weight and so on - well, french people are not dumber than others but as it’s in technical english, it’s not obvious
Windows 10 64 bits
I don't remember what's all in the video, but there are many ways to view the antijunk score for a message:
1) When you open the message, there's a banner at the top that shows you the score
2) Right-click on the message in the message list and select AntiJunk -> Show evaluation
3) Add the "junk score" column to the message list (main menu: Messages / edit columns)
4) If you enable "advanced options" (main menu: Tools / Options / General); then there's an information box above the message list showing you antijunk information for the selected message, including the score
5) Hover your mouse over the "junk evaluation" or "junk score" column in the message list
Thanks for the informations. I have already seen the banner on the top. Very handy.
Windows 10 64 bits
