Max devices error
pesi
Max devices error
Post by pesi »
Hi, I have just updated the program but I can't activate the plus pack (error #4) I use pop peeper on 3 PC at the same time but I never had this kind of problem. Do you have changed something? Thank you in advance
Re: Max devices error
Sorry for the inconvenience -- your license has been updated and you should be able to activate it now. Let me know if you still have a problem.
And, no, this hasn't changed in v4.3, I think it was just coincidence :(
pesi
Post by pesi »
hahahaha, now it says "too many login attemps"... nevermind I'll try later. Tank you for the fast support.
Sorry, I should have cleared that earlier -- things are a little hectic the day of a new release :)
It's cleared now, but you will need to exit/restart POP Peeper if you want to activate it now; otherwise it has an internal timer that blocks further attempts (I forget how long exactly, 1-2 hours after your previous attempt...?)
