I get the following error when trying to log into my Yahoo email accounts.
SSL connection failed (certificate failed: certificate has expired (10))
I have installed all the latest versions of everything but still can't get any of my emails. I can log in to each account separately using Yahoo.
Not sure but this seems to have coincided with the latest Windows 10 update.
SSL failure certificate expired
Re: SSL failure certificate expired
Please post the entire error overview information for us. That is click on the yellow exclamation in the lower-right corner of the main POP Peeper interface and press the "Copy" button and then paste that information to this forum (right-click and select "Paste" from context menu). This information provides us with additional information that may help to analysis your problem.
Just as a reminder, this is always recommended any time a POP Peeper error is encountered and can be found on the following announcements page: Information for new users & forum members in which you will find by scrolling down toward the bottom of the page the following:
If you are still unable to find a solution, then create a new topic (in the appropriate sub-forum). Please provide as much detailed information possible about the issue you are having - including the text of any error messages POP Peeper is showing by following the instructions provided in the Sticky topic below:
PP error messages: How to view them & copy/paste into your post.
GaryS -- please download the patch here:
https://www.esumsoft.com/pop-peeper-beta/
and let us know if that fixes the problem or not.
