PP not auto check both gmail accounts
hime3
Post by hime3 »
PP automatically checks & downloads 1 gmail account.
Previously auto checked & downloaded both (2) gmail accounts.
Settings are identical in both gmail accounts.
Right click to check second gmail account; PP logs in and downloads email.
Any idea why auto checks 1 and not second gmail account?
thanks
hime
Re: PP not auto check both gmail accounts
If all settings are exactly identical in both accounts then both accounts should of course perform the same exact way.
So presumably all protocol settings are exactly the same for both Gmail accounts and you are not getting any errors in the account that does not work and there have been messages to retrieve that did not get retrieved (last point is because you might not have noticed the account checking mail in the status bar if it was done rapidly).
Here are a few things that could possibly produce the results you are getting that may have been overlooked other than email protocols which are presumably all identical for both accounts:
1) When editing the account that is not getting Mail Checked in the "General" Page; is the "Enable" checked in the lower-left corner?
2) When editing the same account in the "General" page; is "Password protected" unchecked (presumably the same as the account that works)?
3) When editing the same account in the "Advanced" page; is the "Retrieval Option" set to "Default" and the Polling Interval above that "0" (which is use default)? (if either of these settings are not set as such then Mail Check time-frame intervals for the account may differ from the other account)
4) Under Tools>Options>Mail Check; is "use one timer for all accounts" selected in upper-right corner of interface? (if not then tick that enabled).
5) Under Tools>Options>Mail check; are any of the "Retrieval Options" set to "Number of messages"? (if so change that to anything else).
6) Under Tools>PPtweaker>Connection; are the time-outs in the account that fails to Check Mail the same as the account that works?
Other members of the the Esumsoft Team may have additional comments/questions as well.
If all the above checks out then as a last resort check the Gmail account settings on the web to make sure the account not doing Mail Checks is the same as the other account. More specifically (clicking on gear in upper-right corner and select "Settings"), check "Filters and Blocked addresses" settings and more importantly check the "Forwarding and POP/IMAP" settings to make sure the two Gmail accounts are the same.
Presumably, the account is disabled as-per lakrsrool's suggestion #1. If it helps in general, you can show which accounts are disabled/enabled all the time by selecting main menu: Accounts / "Show enabled checkbox" -- this also allows you to enable/disable accounts with a single click.
