None of my Yahoo accounts are working with PP Pro, they give Error: Try again later. (-11). This started on 6th October.
POP Peeper: 4.4.1.0
Webmail: 4.4.8.0
SSL: 1.0.2.11
IMAP: 4.4.0.0
RSS: 4.3.0.0
SendMail: 4.4.0.0
Notification Skin: 4.3.0.0
Notification Voice: 4.3.0.0
Profile Picture: 4.3.0.0
AntiJunk: 4.4.0.0
Spell Checker: 4.4.0.0
Web of Trust: 4.4.0.0
--- Web Test ---
Result: 200
Error:
Time: 11:05:36 - 11:05:36 (0 s) (+0100)
Data: Sun, 08 Oct 2017 03:05:36 -0700
Account 1 Yahoo [3: Yahoo] ['' (0) SSL: 0] [WebSend: '' (0) SSL: 0] [Consec: 47]
- Error: Try again later. (-11)
Account 2 Yahoo [3: Yahoo] ['' (0) SSL: 0] [WebSend: '' (0) SSL: 0] [Consec: 47]
Account 3 Yahoo [3: Yahoo] ['' (0) SSL: 0] [WebSend: '' (0) SSL: 0] [Consec: 47]
Account 4 Yahoo [3: Yahoo] ['' (0) SSL: 0] [WebSend: '' (0) SSL: 0] [Consec: 47]
Yahoo accounts not working
Reason: Error messages (Account names) edited to remove personally-identifiable information.
Re: Yahoo accounts not working
Morning ElectroDan,
Sorry to hear of the problem you're having with your Yahoo accounts.
One question for you: Are you able to log-in to the accounts on-line via your browser without any problems?
I see the Webmail plugin version you are using is not the most current one, i.e., v 4.4.9.0 (which was just released by Jeff). The new plugin corrects the "Try again later (-11)" error that you (and others) have been receiving in your Yahoo accounts.
POP Peeper normally automatically updates the Webmail plugin.
To force POP Peeper to update, go to Help / About, make sure that both options (Automatically check for updates and Auto-update webmail plugin) are enabled and then press the "check version" button.
Alternatively, you can manually download/update the plugin via the link below:
https://www.esumsoft.com/products/pop-peeper/plugins/
Just scroll to the bottom of the page to see the plugin. Installation instructions are also provided there as well.
Other members of The Esumsoft Team will also review your topic and provide additional feedback they may have as well.
Please post back and let us know if your issue is resolved, or not.
Thank you & best regards.
Thanks, it's working now the webmail plugin updated
You're welcome. Glad everything is working properly again.
Cheers!
Cheers!
