PP 4.5 install is still 4.4.2.0
gordon
Post by gordon »
I believe I installed PP 4.5, but I am still using 4.4.2.0 :-(
This is what I did:
Go to: https://www.esumsoft.com/productrequest/
entered my email
select submit
This downloaded: POPPeeperPlusPack-Install-v45.exe
I ran it, and it look like it went ok (PP PPpro activated)...
But when I go to PP/about/check version, I see 4.4.2.0 for PP
Did I make a mistake?
POP Peeper: 4.4.2.0
Webmail: 4.4.4.0
SSL: 1.0.2.11
IMAP: 4.4.2.0
RSS: 4.5.0.0
SendMail: 4.4.2.0
Notification Voice: 4.5.0.0 (disabled)
Profile Picture: 4.5.0.0
AntiJunk: 4.4.0.0
Spell Checker: 4.4.0.0
Web of Trust: 4.4.0.0
(none)
Re: PP 4.5 install is still 4.4.2.0
The file that you downloaded contains *only* the Plus Pack. If you still have the email, the download link you want to use is the 3rd one, which says:
"You may also download the full installation which includes POP Peeper Pro and the Plus Pack:"
The downloaded install file will have the name: POPPeeperProPlus-Install-v45 (not the POPPeeperPlusPack-Install-v45.exe you downloaded and installed).
