Max Devices (Error #4)
rpdii.cdn
Post by rpdii.cdn »
Hiya... Trying to install POP Peeper and activate the Plus Pack, and I receive a "Max Devices (Error #4)" error.
It's my understanding I can activate POP Peeper on up to three computers. I've installed POP Peeper on a number of computers over time, including some VMs, too, so I'm not surprised I've exceeded three.
I've settled on two now (desktop and laptop). So... Is there a way for me to deactivate an activation? This would be particularly helpful if I could deactivate an installation manually just before I reinstall the OS or prepare to trash a VM I'm not going to use anymore.
Cheers, and thanks for a great product.
Re: Max Devices (Error #4)
Welcome to the forums rpdii.cdn.
Unfortunately, you can't clear out any of the devices yourself, it's either done automatically by the system (in certain cases) or needs to be requested. I've gone ahead and cleared out several of your old devices so you should be able to activate it again now. Sorry for the inconvenience.
rpdii.cdn
Post by rpdii.cdn »
That fixed things. Thanks very much!
